Low quality in Adobe Encore
COW Forums : Adobe Encore DVD
Sam Alderson
on Aug 3, 2011 at 11:05:05 pm
I have exported high quality (1920x1080 lossless) footage from Adobe After Effects. Now when I take it into Adobe Encore to make a DVD I find that it loses all its quality once it's transcoded. Unless I burn it to blu-ray it can't keep its original 1920x1080 size and I've tried many different transcode settings as well as exporting a mpg2-DVD from After Effects and it seems like none of them would look high quality on a television.
eric pautsch
Re: Low quality in Adobe Encore
on Aug 4, 2011 at 12:33:04 am
DVD is 720x480 NTSC / 720X576 PAL.
Sam Alderson
on Aug 4, 2011 at 12:50:32 am
But how does that work on a TV or even computer? It just doesn't seem to produce high enough quality?
I'm sorry for the stupid questions I am just confused.
Daniel Ludwig
on Aug 5, 2011 at 5:24:32 am
Hey Sam,
your eyes are irritated by the HD-picture. SD-picture allways looks like you have a big blur on the footage - compared to your original HD-quality.
SD-DVD only allows 720x480 for NTSC or 720x576 resolution for PAL as eric discribed.
and television/broadcast is working with the same resolutions. if you playback a DVD on a computer, it is the same - but most software-players scaleing the picture to full screen, and using no good scaling-allgorithms.
you see there is no other way to go - if you would like to have better picture-quality on optical discs you need to go blu-ray.
cheers
danny
