Return to loop ponit at Encore CS5
COW Forums : Adobe Encore DVD
Carlos Rocha
on Jul 29, 2011 at 12:41:00 pm
Hi Everybody!
I have a Video to the Menu with 38 seconds. I have done a loop point at 23:27 seconds and would like the movie of timeline, at run all, return to Menu but to the loop point and no to begining of Menu.
How i do it?
Thanks.
Jon Geddes
Re: Return to loop ponit at Encore CS5
on Jul 29, 2011 at 5:03:37 pm
Set the End Action of the movie timeline to return to the loop point of the Main Menu.
Click the drop-down arrow in the field for the timeline's end action, then go down and select 'Specify Link'. In the window that pops up, select the main menu (and a particular button if you want), then at the bottom of the window, make sure "Set to Loop Point" is checked, then click OK.
Jon Geddes
http://www.precomposed.com
Carlos Rocha
Re: Return to loop point at Encore CS5
on Jul 29, 2011 at 9:08:31 pm
This form?
http://www.carcleo.com/img.png
Not work.
Sorry.
I am a brasiliam.
Please, not see to my "English". Ok?
Thank you
Jon Geddes
on Jul 29, 2011 at 9:59:22 pm
Have you tried building your disc?
The Encore preview is not an accurate representation of how the final disc will function.
Jon Geddes
Carlos Rocha
on Jul 29, 2011 at 10:21:40 pm
Ok.
I yet not tried.
I will try and later put here the result.
Carlos Rocha
on Jul 29, 2011 at 10:37:36 pm
Yes.
It is.
Thank you for all.
So work.
At prewier of Encore not work. But, buildind, yes. Work.
Thank you again.
