No Highlights on Encore CS3 for Mac?
COW Forums : Adobe Encore DVD
David Eves
on Jul 23, 2011 at 2:26:39 am
I was recently using Encore for the first time on my 2010 iMac and ran into a bit of a jam. When making any sort of menu, the menu highlights don't always seem to show up on the DVD. I can see the menu highlights just fine when the disc is being played on a computer or a bluray player, but when in a regular old fashioned DVD player, I get a unnavigable menu. Anyone else seem to encounter this problem, and if so, does anyone have a solution?
Jon Geddes
Re: No Highlights on Encore CS3 for Mac?
on Jul 24, 2011 at 9:38:00 pm
This is a well documented problem with Encore and the Mac OS. What you need to do is edit the menu in Photoshop, and change the highlight layer prefix from (=1) to (=3). Then in Encore, you may need to change the color of the (=3) highlight colors in the menu color set.
Jon Geddes
http://www.precomposed.com
David Eves
on Jul 27, 2011 at 8:16:49 pm
Changing the prefix from (=1) to (=3) worked like a charm. Thank you thank you THANK YOU.
