Mastering question regarding dual layer discs
COW Forums : Adobe Encore DVD
Paul Allen
on Jun 20, 2011 at 8:16:59 pm
Hi all,
It was my understanding that using encore I would be able to export a digital master (DDP) which could be sent to a replication facilility instead of the old system of using DLTs. Am I correct in thinking this, and is it possible with a dual-layer dvd? It's not as clear as it could be in the help section. Just want to check before I start building the whole project in Encore.
Cheers,
Paul
Avid Media Composer. PC with Intel DP35DP s775 iP35 ATX motherboard. Core 2 Extreme CPU QX6800 2.93GHz (4 CPUSs). 2030MB RAM. 256MB Nvidia Quadro/FX1500 PCIe
minu sharma
Re: Mastering question regarding dual layer discs
on Jun 21, 2011 at 3:52:02 am
Hi ,
Yes You are correct , DDP images can be created from encore and can be sent for replication.
You can also create DDP for dual layer projects . In This DDP Image will have two folders for different layers .
Select DDP image from encore build panel and create DDP from project , DVD folder or DVD image .
If you want to set any copyright protection create DDP image from project itself.
Minu
