18 Buttons Limitation?
COW Forums : Adobe Encore DVD
Charles Fasano
on May 27, 2011 at 7:02:36 pm
Why is there an 18 button limitation in Encore CS5 and DVD Studio Pro when working in 16:9?
Daniel Ludwig
Re: 18 Buttons Limitation?
on May 30, 2011 at 4:33:05 pm
charles,
this is a DVD-spec-thing, you can´t change it - you need to live with it!
there are no more buttons possible than 18 for 16:9.
cheers
danny
Phil Condit
on Jun 13, 2011 at 7:37:06 pm
I am building a DVD for a feature film with 20 chapters accessed through three "Scene Selection" sub menus. I checked the project and came up with no errors. But when I tried to build it I got an "Encoding Failed" message, with no elaboration. Am I using too many links/buttons?
Daniel Ludwig
on Jun 13, 2011 at 7:42:09 pm
simple answer: yes you do!
there is a 18button-limmit within DVD-spec at 16:9 or 24 buttons at 4:3.
so you need to create a 2nd page for chapter-selection.
cheers
danny
Phil Condit
on Jun 13, 2011 at 8:42:49 pm
Thanks for the facts. I looked at everything Lynda.com had on Encore, but I must have missed that point. Just so I'm clear - I may only have 18 links/buttons TOTAL on my DVD. Right? That' means I have to cut my chapter selection down a lot if I want to include featurettes on the making of. How do the makers of DVDs of Hollywood movies get around the limitation? Between scene selection options, outtakes (one at a time/play all) director's comment track, the inspiration, the design, the making of, the acting, the special effects, poster gallery and previews it seems like I'm already over the limit.
Daniel Ludwig
on Jun 14, 2011 at 2:06:23 am
it´s not a limit of 18 button over all, it´s just a limit for each menu.
so you can have 2 chapter-menu-pages with 18buttons each menu. it´s just a bit work of re-designing and relinking the buttons, and of course linking these two chapter-pages to each other.
cheers
danny
Phil Condit
on Jun 14, 2011 at 4:07:00 am
Hi Daniel,
Here is one of my Scene Selection pages (I hope). It looks to me like I have 10 buttons. There are highlights on all of them. Do the highlights count as buttons?
Phil Condit
on Jun 14, 2011 at 4:13:32 am
Hopefully the image will be attached to this response.
Phil Condit
on Jun 14, 2011 at 4:16:42 am
http://i1.creativecow.net/u-upload.php#
This is the screen grab of my Scene Selection page - again, I hope.
Charles Fasano
on Jun 14, 2011 at 6:24:31 am
My apologies for the delayed reply. I've been busy with my movie premiere this week. 18 buttons per page is the limit for 16:9. I'm not sure how many pages you're allowed. I solved my problem by grouping 2 separate chapters together into a single button. So instead of "Eagle Rays" and "Manta Rays" as separate buttons, it is now a single button for "Eagle and Manta Rays". It starts with the Eagle and if the viewer wants mantas right away, they can press the next chapter button.
Daniel Ludwig
on Jun 14, 2011 at 12:07:04 pm
I don´t know exactly what you mean by that?!
buttons mostly having highlights as well, could you post a screenshot of it, or upload the PSD-file?
cheers
danny
Phil Condit
on Jun 14, 2011 at 3:39:35 pm
Hey - it helps if I read the directions. Here is the screen grab I've been trying to send. It has 10 buttons, each with a subpicture highlight.
Daniel Ludwig
on Jun 14, 2011 at 6:14:31 pm
hi phil,
that menu is looking good - there should be no problems with this menu...
cheers
danny
Phil Condit
on Jun 14, 2011 at 6:42:38 pm
Thanks for your help! So now I guess I have to go back to my original problem that when I tried to build the DVD I received a "Encoding Error" message with no elaboration. If my project checked out without any errors before I tried to build it, what can I look for now? Or should I start a new thread?
Daniel Ludwig
on Jun 15, 2011 at 7:55:54 am
the error-message is encoding error!?
so have you encoded your assets (films) prior authoring or not? it´s better to encode them using adobe media encoder first, then start authoring.
NOTE: before you encode your stuff, you need to do a bitbudgeting.
cheers
danny
