Encore error: Sense Code 37202
COW Forums : Adobe Encore DVD
Janus Vinther
on May 27, 2011 at 8:57:23 am
When I burn a normal project with a normal DVD-menu (made in Photoshop)and 2-3 movieclips,why do I sometime get this error:
"Encore was unable to complete the operation because of a hardware error (Sense Code 37202). Please contact the hardware manufacturer for more information."
The project work perfectly and when I do the Check Project, everything seems to be perfect. The burning starts up normaly, but it ends up with the error-message and the DVD don't work.
Hope you can help me with the problem.
// Janus.
minu sharma
Re: Encore error: Sense Code 37202
on Jun 15, 2011 at 9:41:48 am
Hi
This error is hardware related error , Either your burner is not recognized by encore or you are using a bad media . Change disc , check burner connection and try again .
Minu
Janus Vinther
on Jun 19, 2011 at 11:33:53 am
Thanks. I think the problem is fixed.
Janus Vinther
