Problem with "Jumping" Transitions
COW Forums : Adobe Encore DVD
Glenn Challenger
on May 6, 2011 at 10:08:14 pm
Hi all,
I have a problem with transitions that are "jumping" in Encore. I used the method that we all know... Menu A, links as a transition to a .mov that has Menu A as it's first frame and Menu B as its last frame.
My problem is that when the transition plays, the size of the mov plays back at approx. 105% scale, while the menus remain at 100% scale. Resulting in a size "jump"
Everything played back fine in preview, I've only had this problem since transcoding. I noticed it on my first disc, and now it shows up on preview as well.
Is this a transcode problem? Both the menu and the transition were at NTSC 720x486.
I hope this makes some sense to someone. I need smooth transitions!
Any suggestions?
Daniel Ludwig
Re: Problem with "Jumping" Transitions
on May 8, 2011 at 7:18:20 pm
glenn,
MPEG2 on DVD will be scaled to 720x480. in real it will be cropped 3 px on top and bottom of the picture.
cheers
danny
Glenn Challenger
on May 8, 2011 at 7:32:04 pm
Thanks Danny. I haven't had a chance to try that out but the 6 total pixels seems to be exactly how much it is "jumping" in. I'm sure I'll be able to fix it if I keep this is mind and compensate for it.
Glenn
