Blu-Ray Error: "fatal error" MAC.
COW Forums : Adobe Encore DVD
Alexander Higgins
on Apr 24, 2011 at 11:37:54 pm
My error
Blu-Ray Error: "fatal error", Code: "6", Note: "Video buffer underflows. Total bitrate is too high near time = 1.920000 seconds -
I am using CS5 Encore on OS X 10.6.4
I am authoring a Blu-Ray Project, 25BG, media is already encoded in SQUEEZE and was tested in Toast11 PRO. So the test in Toast 11 Pro proves that the media is fine and bit rate it not too high.
Anyway, I need to make menus and do other things to make the project loop around and play in certain spots, stuff that Toast cant do.
Anyway, I get that error everytime all the time. I have read through all the forums and I have tried, naming the .iso and the build folders simpole names. I have drive to build to different drives. I have tried everything..
My guess is that Encore just doesn't like 3rd party H264 encoders???
Alexander Higgins
Re: Blu-Ray Error: "fatal error" MAC.
on Apr 26, 2011 at 5:41:57 pm
I have been testing for almost 4 days, doing every little trick to try and get the BLU-RAY to build. Still get that error. It seems that ENCORE just doesn't work for mac.
Daniel Ludwig
on Apr 27, 2011 at 9:03:17 am
alex,
encore could handle 3rd party H264 and it´s working well on mac, too - but maybe it has a problem with squeeze-encoded files!
which version of squeeze do you use? will it create H264-elementary streams?
please tell us your other encoder-settings?
I allready created a lot BDs that has been replicated, too. there were no problems.
cheers
danny
Alexander Higgins
on Apr 27, 2011 at 5:09:51 pm
Hey Daniel, I am using squeeze 7 for MAC.
I am using the Blu-Ray Disc HD preset Stream Type is Elemnetary
settings
Codec -- MainConcerpt H.264
Data Rate Target 20,000 kbps
Entropy Coding Mode: CABAC
Daniel Ludwig
on Apr 27, 2011 at 6:35:14 pm
hi again,
could you upload a short test-file, so I can check it over here?
cheers
danny
Alexander Higgins
on Apr 27, 2011 at 7:01:26 pm
Sure, let me figure out the best way to do that.. Also, I have tested the media in Toast Pro 11 and it seems to work fine there.
