From square pixel to PAL Widescreen.
COW Forums : Adobe Encore DVD
Carlos Zapater
on Apr 19, 2011 at 9:19:06 am
I have the exact same problem that is written here
I come from a PPRO timeline 1024x576 square pixel and I want to make an SD PAL Widescreen DVD with Dynamic link (importing directly the sequence as asset). And I'm not able to set the proper aspect ratio in the output result. The first reply to the other post suggest to create a new timeline and set PAR before attaching whatever. But when I create a new timeline I don't see any option to change aspect ratio nor pops up any menu with options to that timeline.
Searching through the forum I found several ways to change aspect ratio and that confuses me more. I thought you could set up the project as widescreen like DVD Architect and the program modifies the PAR automatically in the files to match it.
The DVD is a standalone clip. No menus. Only autoplay of the sequence and loop again.
Thanks for your help.
© 2018 All Rights Reserved
