Error LOADING TRANSCODE PRESET
COW Forums : Adobe Encore DVD
Richard Angelous
on Mar 29, 2011 at 6:49:46 pm
Hi, does anybody knows anything about how to fix this problem
"Error loading transcode preset"
any idea?, I already uninstall and re-install the program and try different versions and the same problem remains
I hope someone can have any clue, thanks
Jon Geddes
Re: Error LOADING TRANSCODE PRESET
on Apr 6, 2011 at 8:27:13 pm
If you created a custom transcode preset and used it in a particular project, then reinstalled the program or transfered the project to a different system, that preset will not be found and it will have issues loading.
Jon Geddes
http://www.precomposed.com
Richard Angelous
on Apr 9, 2011 at 3:15:18 am
correct, but do you have any idea about how to fix the problem, I don't care about the presets, neither previous proyects, I just need encore working as usual on just one computer
I can not find any solution
Jon Geddes
on Apr 9, 2011 at 3:50:06 pm
Do you have access to the computer that the project was originally created on? If so, you might be able to copy the preset over to your current system if you can locate it. If you simply have reformatted your system since you last worked on that project, I'm not quite sure how to resolve it. This issue is one of the reasons that I stopped creating custom transcoding presets in Encore. I now transcode all my videos before bringing them into Encore, and only use the existing presets for the transcoding of the motion menus.
Jon Geddes
