720P on DVD
COW Forums : Adobe Encore DVD
Emilio Kyprianou
720P on DVD
on Mar 6, 2011 at 5:05:01 pm
I need to burn a Clip that is 720P onto a DVD, i don't want it to be down scaled but rather have the full Bit rate and resolution ( it is very short about 3 minutes). It could be shown on a DVD player and look better and a HD set. If the full resolution burning really is impossible, then how could i give it a HD bit rate ( like the super bit DVD ) . However i would like to give it a HD resolution.
Thank you
Daniel Ludwig
Re: 720P on DVD
on Mar 6, 2011 at 10:54:04 pm
DVD means SD by spec, means 720x480 (NTSC) or 720x576 (PAL). if you would like to have 720p you need to go blu-ray-disk. that´s the only HD-way to go.
© 2018 All Rights Reserved
