BD Pop-Up
COW Forums : Adobe Encore DVD
Eric Santiago
BD Pop-Up
on Feb 10, 2011 at 9:06:10 pm
Ive tried everything with the resources I found on the internet and nothing.
Basically I have 5 buttons (labeled correctly) I need as buttons for Pop-Up option.
However, I also want this box behind them along with the Pop-Up window.
If I dont turn the box layer into a button, it doesnt show up.
If I do turn it on as a button it gets in the way of things.
How do I add a layer in the Pop-Up without having to use it as a button?
Also any way of testing Pop-Up during Preview?
Whats the keyboard short-cut?
Jon Geddes
Re: BD Pop-Up
on Feb 11, 2011 at 4:03:28 pm
Pop-up graphic layers must be part of a button group. So if you wanted a graphic to extend behind multiple buttons, you will have to split up that graphic into multiple pieces, and place each piece into the button group that it lays over. If done properly, you will not see where the graphic is split up among the different buttons.
If you want to see an example, just download a pop-up menu from the Encore resource central.
Jon Geddes
http://www.precomposed.com
Daniel Ludwig
Re: BD Pop-Up
on Feb 11, 2011 at 5:00:00 pm
... and to create it properly - it´s called sliceing - is a bit more work to do.
cheers
danny
Eric Santiago
Re: BD Pop-Up
on Feb 11, 2011 at 7:59:26 pm
Thanks Jon and Daniel.
I had an inkling that I would have to start treating this like Web authoring. My failure was that I didnt use the Adobe layer naming convention and just used a basic PSD layer file.
Thanks again :)
