exporting video to dvd via Adobe CS5
COW Forums : Adobe Encore DVD
Kirk Sibley
on Feb 5, 2011 at 10:55:41 pm
I just purchased my first HD camera (Canon HFS20). I did some filming in HD 60i and want to take this all the way through the process of exporting this to dvd using adobe encore.
I tried selecting the avchd 1080i 60fps sequence setting and exporting to DVD using the dynamic link option, but in the end my footage came out looking very interlaced and bad.
I know enough about video editing to be dangerous but exporting to dvd I'm just familiar enough to know the differences between interlaced and progressive, but not enough to eliminate the issues i'm seeing on screen. I tried searching through the archives of this forum and there were similar posts but i still can't find the right resolution to resolve the issues.
Daniel Ludwig
Re: exporting video to dvd via Adobe CS5
on Feb 6, 2011 at 11:21:27 am
hi,
I guess your problem is wrong field-dominance.
HD1080i60 is upper field first but SD NTSC is lower field first, so you need to tell the encoder to encode upper first to keep the lines in the right order.
so - I guess you need to create your own encoding-preset and encode it again.
cheers
danny
Kirk Sibley
on Feb 6, 2011 at 4:09:31 pm
so what sequence preset and export setting would you suggest? I can keep the sequence settings AVCHD 1080i 80, which already set the field dominance to upper first (see below). when i export i export in mpeg 2 and select match source attributes which produces the settings in the screen shot (also below). Does this sound like what you are asking? The match source attributes setting sets the field dominance to upper as well
For editing AVCHD Formats recorded in 1920x1080 square pixels (non-anamorphic).
16:9 interlaced HD video at 29.97 frames per second.
48kHz audio.
Drop-Frame Timecode numbering.
General
Editing mode: AVCHD 1080i square pixel
Timebase: 29.97fps
Video Settings
Frame size: 1920h 1080v (1.0000)
Frame rate: 29.97 frames/second
Pixel Aspect Ratio: Square Pixels (1.0)
Fields: Upper Field First
Audio Settings
Sample rate: 48000 samples/second
Default Sequence
Total video tracks: 3
Master track type: Stereo
Mono tracks: 0
Stereo tracks: 3
5.1 tracks: 3
Submix mono tracks: 0
Submix stereo tracks: 0
Submix 5.1 tracks: 0
Daniel Ludwig
on Feb 6, 2011 at 4:56:06 pm
hi,
for DVD you need to go 720x480@29.98 16:9 upper field first.
cheers
danny
Kirk Sibley
on Feb 6, 2011 at 4:38:01 pm
...here's the screen shot...
Daniel Ludwig
on Feb 6, 2011 at 10:26:13 pm
1. you are using VBR instead of CBR
2. don´t use PCM audio for you DVD, it´s THE reason in 90% of all cases why DVDs will not play smoothly. again, as mentioned before - use dolby digital audio@192kbit/s
cheers
danny
Kirk Sibley
on Feb 7, 2011 at 3:46:40 am
are you saying i should use vbr or cbr?
Daniel Ludwig
on Feb 7, 2011 at 3:22:46 pm
you should use CBR for small projects.
cheers
danny
