Blu ray 3d
COW Forums : Adobe Encore DVD
mike moncrief
Blu ray 3d
on Jan 22, 2011 at 1:24:14 am
Hi all,
Does Adobe Encore CS 4 or CS5 have the ability to burn a Blu Ray 3D disk?. Or is this require special software?? Any ideas or recommendations are appreciated..
thanks
mike m.
Mike Moncrief
http://www.razorpostproduction.com
eric pautsch
Re: Blu ray 3d
on Jan 22, 2011 at 1:45:43 am
No...you need specialty software. Its pretty much a beta technology at this point no matter what piece of equipment you buy or use....even for the studios with millions of dollars and the brightest minds.
http://www.netblender.com/main/
http://www.sonycreativesoftware.com/bluprint
http://www.sonic.com/enu/products/professional/default.html
mike moncrief
Re: Blu ray 3d
on Jan 22, 2011 at 1:48:04 pm
Thanks so much..
Mike Moncrief
mike moncrief
Re: Blu ray 3d
on Jan 22, 2011 at 2:26:09 pm
Anyone know of any service where you send them a 3d file and they author the Blu Ray 3D for you ??
Thanks..
Mike Moncrief
eric pautsch
Re: Blu ray 3d
on Jan 22, 2011 at 2:59:27 pm
You actually need two files (left and right eye) to encode. If you contact me offlist I can forward you a name. Just a word of warning...it very expensive. Near $200 per minute of video not including the authoring.
poweragemedia at yahoo
Daniel Ludwig
Re: Blu ray 3d
on Jan 23, 2011 at 10:25:46 am
hi,
your alternative could be to buy mainconcept MVC-encoder for approx. 2500€ and encode your stream yourself - but then you still need someone to author the disk.
even sonic cinevision is using mainconcept encoder engine - however mainconcept was bought by sonic last year.
cheers
danny
Jonathan Marlow
Re: Blu ray 3d
on Feb 10, 2011 at 12:57:09 am
Couldn't you produce a single stream image that is frame packed (i.e. side-by-side) and create your Blu-Ray that way? Would just be a matter of setting your 3D TV to the right setting to play back properly. It's essentially "half" resolution, but then again the way 3D Blu-Ray is being authored today it has to be 720p 60 or bust.
eric pautsch
Re: Blu ray 3d
on Feb 10, 2011 at 2:17:37 pm
No MVC encoders require 2 streams either shot this way or converted from a 2D image. Here's a good read:
http://www.netblender.com/main/resources/understanding-3d/blu-ray-3d-faq/
tyler Granlund
Re: Blu ray 3d
on Feb 16, 2011 at 7:17:13 pm
I do it all the time using the side side method. Works great. The tv's handle it just like the broadcast 3d stuff on espn.
Lukas Kogler
Re: Blu ray 3d
on Mar 11, 2011 at 11:15:54 am
Hello!
But the question is how? I have a encore CS5 project with sidbyside content. How can I give the program the information so that the the 3D player/3D TV will recognize the 3D content?
Thank you very much, Lukas
tyler Granlund
Re: Blu ray 3d
on Mar 11, 2011 at 5:26:07 pm
Any 3D TV on the market today has the ability to tell it you are displaying 3D content, depending on some variables the television automatically recognizes it or doesn't.
That said if you have properly formatted your side/side or top/bottom content, in your tv go to the 3d menu, where you can manually turn on 3d mode, and there is on the three sets i use (Samsung/Panasonic/Sony) an option to tell the set what signal your feeding (side/side, Over/under) once 3d mode is on, and you select the correct display, the set will process the image accordingly. As long as you have formated your output properly.
I have done this many times for screening 3d off an encore blu ray using a ps3 and a standard blu ray player as well.
Roxas Yong
Re: Blu ray 3d
on Mar 30, 2011 at 8:10:07 am
Hi Eric, may i get the contact of the organize which provide service for authoring 3D Blu-ray from you please?
