how to burn sd project to blu-ray in maximum quality?
COW Forums : Adobe Encore DVD
Peter Lovibond
on Dec 28, 2010 at 5:35:24 am
I have a standard definition DV project (PAL 720x576 50i) that I plan to burn to DVD. However I have a blu-ray burner in my computer so I was wondering if I could also burn my project to a blu-ray disk with higher quality, ie less compression, due to blu-ray's greater capacity? Or possibly no additional compression at all? I am using CS5 Master Collection so I have access to After Effects if needed.
Peter
Chaddix Malchow
Re: how to burn sd project to blu-ray in maximum quality?
on Feb 26, 2011 at 9:52:55 pm
you can, when exporting out of adobe premeire,which im assuming youre using, select mpeg2 - blu ray, and under resolution, theres an SD option for 720x480 in NTSC, so just make it PAL, boost the bitrate, throw it in encore and you're good to go
Peter Clovelly
on Feb 27, 2011 at 10:00:14 am
Thanks Chaddix - I hadn't seen that setting, so I'll check it out.
Peter Clovelly
on Feb 27, 2011 at 1:23:03 pm
OK that worked well. My test footage was only 6 min long so I maxed out the encoding settings: CBR 40 Mbps, M frames 2, N frames 8. Played nicely in my Blu-Ray player.
Thanks again.
