DVD build not working, but Flash build is?
COW Forums : Adobe Encore DVD
daniel bacchiocchi
on Dec 18, 2010 at 3:14:27 am
I created a dvd in Encore CS5. The dvd previews fine and i can build a working Flash version. However when i create an image or disc "DVD" it will not start and says "Application not found"
I have a menu set as first play, is that ok?
Dvd goes like this:
Disc-> Menu 1
chapter 1 ------------------>Menu 2 ---slideshow
chapter 2 ------------------>Menu 3 ---slideshow
chapter 3 ------------------>Video 1
I set first play to Menu 1. In the same properties the "main timeline" is video 1. I checked for project errors with "check project" but did there were none.
If it previews fine and builds flash fine shouldn't it burn or image fine too?
