Next Chapter Problem...
COW Forums : Adobe Encore DVD
Mike Moss
on Nov 15, 2010 at 10:02:49 pm
Ok...
I have 1 Main Menu and 1 Sub Menu (Chapters)
I also have only 1 Timeline...
All buttons are linked and everything works except one thing...
The "Next Chapter" button on the virtual remote.
However i choose to play the movie, wether i press "Play" (To play the entire movie) Or if i go to the Chapters menu and select a certain chapter(I have 7 chapter points BTW...)
The next chapter button does not work.
When i start the movie from the beginning and i press next chapter, it jumps to the next chapter and immediatly bounces back to the beginning. Whats weird is in the monitor it shows the correct chapter number and time, but movie still plays from beginning. If i select a chapter from the chapters menu it starts from the correct spot...then next chapter bounces back all the way to the beginning again...What am i doing wrong here??
Ricky Barrow
Re: Next Chapter Problem...
on Nov 16, 2010 at 1:52:06 pm
What version Encore? Are you using playlist(s)? Double check all links and especially end actions for chapters or playlists.
Ricky
Mike Moss
on Nov 16, 2010 at 4:15:00 pm
I'm using CS3.
I checked everything, double checked and triple checked...
I went ahead and wrote the DVD with the bug anyways, And works fine in a DVD player. Still acts funny inside of Encore.
Would still like to know why that happens, But hey! It's working when i need it too...
