Best format from Premier
COW Forums : Adobe Encore DVD
Rich Rubasch
on Oct 28, 2010 at 3:21:37 pm
Have a Premier project with Blackmagic AVI codec at 720 59.94 and need to send 15 sequences to Encore for a BluRay output. Is there a setting in Encore that automatically detects the 720 clips from Premier and formats and encodes the disc to 720? Or should I encode the sequences first to self contained clips in a folder and bring those into Encore?
Exporting the sequences directly to Encore is taking forever. I think sending the sequences thru media encoder and creating individual clips would be faster, but is 720 59.94 a proper format for BluRay and is there any preference in Encore that needs to be set to specify a 720 project?
CS4, PC.
Rich Rubasch
Tilt Media Inc.
Video Production and Post
Owner/President/Editor/Designer/Animator
http://www.tiltmedia.com
Daniel Ludwig
Re: Best format from Premier
on Oct 29, 2010 at 6:51:45 am
Hi Rich,
the best way would be to export your clips from premiere as a self-contained file.
afterwards import them into encore if you need specific chapter-marker and let encore encode the clips with the chaptermarker on the timelines.
if you wont need specific chaptermarker on a specific TC you an also do a bach-prozess within adobe media encoder to create your assets.
if you starting encore make sure your project-settings are 720p59.94 if not, all your material will be scaled to the selected format (1080 for example).
als be awared that you canĀ“t use different input-materials with encore as the BD-spec normally allow.
all stuff will be scaled/transcoded to the selected setting.
and finally - yes, 720p59.94 is part of the BD-specs.
cheers
danny
Rich Rubasch
on Oct 30, 2010 at 2:05:07 am
That was an awesome response....thanks!
Rich Rubasch
Tilt Media Inc.
