Check project novice question
COW Forums : Adobe Encore DVD
Bruce Stubblefield
on Oct 16, 2010 at 4:36:07 pm
Hello,
On a Mac 8-core, running Encore CS4, I'm making a BluRay .iso, starting with a 10 Bit uncompressed 1920x1080 Quicktime of a 90-minute feature. Just a bare-bones screening copy; no menus, just "insert and play." When I get to "build", the check project shows "End action not set" and "Title remote not set." Everything under "Menu" is gray, including "Set End Action." I can't find any information about these problems. Can anyone tell me how to fix them, or if I even need to?
Second issue: When I try to burn the BluRay in Toast 10 on the same machine, working from the BDMV/Certificate folders that Encore made, I get the Toast error, "Couldn't set up the track for writing." Could this be from something I'm doing wrong in Encore, or should I be posting this under "Toast?"
thanks
Bruce S
Daniel Ludwig
Re: Check project novice question
on Oct 17, 2010 at 9:51:29 am
Hi Bruce,
as you´are creating a BD that needs to play the film only (without menus) you can ignor these informations, and go to built straight away.
according to your 2nd issue:
you need to select video>BDMV-folder, then create a new disk and put the BDMV and certificates-folder that you previously has been creating on the right side.
that should work.
last toast-version is 10.0.8.
cheers
danny
Bruce Stubblefield
on Oct 17, 2010 at 8:19:00 pm
Thanks! Much appreciated.
Bruce S
