Trying to import an After Effects comp as a menu.
COW Forums : Adobe Encore DVD
Ian McBain
on Sep 22, 2010 at 4:11:53 pm
Hey team,
I have made a motion menu in After Effects. Whenever I "dynamic link" it into encore, is show up as an Aftrer Effects composition, but I can't make it into a menu. I have made custom buttons in the comp, but the comps aren't showing me any layers.
Am I missing a step? I have the ae comp in encore, and need to make it act like a menu, with all the butons etc.
Any ideas?
Ian
Clint Milner
Re: Trying to import an After Effects comp as a menu.
on Sep 23, 2010 at 10:38:30 am
Hi Ian,
You need to assign the AE project as a Video asset of your menu under the Motion Tab of your Menu Properties.
Alternatively you can click on a blank menu in Encore, Menu --> Create After Effects Comp (which does the above for you and launches AE) and then import your comp that you've already made in AE.
Hope this helps.
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
Ian McBain
on Sep 23, 2010 at 4:02:16 pm
Thanks for your suggestion.
I now have the comp in Encore, it is a menu...but the buttons I've designated (with the (+)) and their respective subpicture highlights are not functioning at all. In the layers panel, it all shows up as one layer "background".
I'm absolutely baffled.
Ian
Clint Milner
on Sep 24, 2010 at 2:24:42 pm
1118_menutest.zip
Here's a sample project and screenshot to show you the way I did it.
Hope that helps.
Clint
12 GB DDR3 RAM
4 TB RAID 5
