Quicktime error with Encore CS4 for Mac
COW Forums : Adobe Encore DVD
Brian Johnson
on Aug 11, 2010 at 10:28:15 pm
Hi all,
I'm having issues with burning DVDs with Encore that has only recently started. Hopefully someone here can help me figure out what's happening.
I have an Encore CS4 Mac project with a dynamically linked SD sequence from Premiere Pro. I've transcoded the video and am trying to burn the project to a DVD. The project file and all source media are on an external WD hard drive plugged in via USB. I've tried burning with my MacBook Pro's Superdrive as well as with a Lacie external Blu-ray drive. It writes to the DVD for a while and then eventually cancels the burn itself. A window pops up that says "QuickTime system error: = -1". I was having this problem last week and after restarting my computer a couple times I managed to get 2 DVDs that were fine after throwing 8 away that had screwed up. Now I'm burning DVDs from a different project and am getting the same error message repeatedly.
Daniel Ludwig
Re: Quicktime error with Encore CS4 for Mac
on Aug 22, 2010 at 1:09:40 pm
Hi Brian,
could you try to create an DVD-disc-image with encore and try to burn this to using the harddisk-utility or toast?
what kind of media-type are you using?
© 2018 All Rights Reserved
