File Not Found Error on preview and build
COW Forums : Adobe Encore DVD
Ray Lupton
on Aug 3, 2010 at 3:44:41 pm
Hi
I'm getting an error whenever I try and preview or build a disk or an image. It seems that Encore CS5 is using old preview files. Is there any way to clean these up safely or a solution to this isse.
minu sharma
Re: File Not Found Error on preview and build
on Aug 6, 2010 at 5:38:17 am
Hi Ray ,
just check whether all your files in the project online , if there is any media offline file present in the project , there is a possibility of this file not found error while building and preview.
Please check your project and if you find any media offline , locate source asset or locate to transcoded file(if present in transcode folder)
Minu
