Using menu multiple times
COW Forums : Adobe Encore DVD
Michael Herp
on Jul 19, 2010 at 10:36:02 pm
I've been using After Effects for quite some time and have just started using Encore. I'm all new to Dvd authoring so I'm not sure what I'm asking is elementary and it's hard to search for this issue because I don't know Encore terminology.
I'm wondering if it's possible to create a submenu and use it for two different directories without having to write the menu twice on a dvd. For instance, Let's say I create a main menu with two buttons labeled 'litho' and 'circa'. Then I create a submenu with three buttons labled 'a', 'b', and 'c'. Is it possible to link 'litho' and 'circa' to the same submenu, but have the content of 'a' 'b' and 'c' (in the submenu) be contingent on whether 'litho' or 'circa' was selected in the main menu?
Thanks for the help!
eric pautsch
Re: Using menu multiple times
on Jul 20, 2010 at 4:15:49 am
You would create 2 separate menus. Professional authors and designers do this all the time.
© 2018 All Rights Reserved
