Encore Menu "Selection"
COW Forums : Adobe Encore DVD
Erik Carlson
on Jul 2, 2010 at 9:18:08 pm
So I don't know if this is possible in Encore or at all even. I have a menu "jukebox". There are buttons linked to each song selection. Is it possible to have the selection prefix be an actual image or does it just work as a solid color?
Basically I have a round button that "sticks out" and I would like for when the user selects that option the button is then "pushed in".
If that sounds confusing
John Rich
Re: Encore Menu "Selection"
on Jul 7, 2010 at 12:43:48 am
I've never done this, so this is just an idea and is pretty complex. It requires a 3d type program which in this case would be Zaxwerks Invigorator Pro. You'd also have to be able to use Illustrator.
http://library.creativecow.net/articles/hamad_serge/depth_scale/video-tutor...
This creates compression of the button.
Then you'd use the render of the button compressing and go to Andrew Kramer's tutorial here.
http://videocopilot.net/tutorials/dynamic_bar_graphs/.
You would make a short clip for each button compressing and then put it into Encore as a button transition for each button.
It might be tough to line up the menu button with the moving button.
Just some thoughts.
John Rich
JOHNR
