wierd subtitle error cs5
COW Forums : Adobe Encore DVD
Roar Amundsen
on Jun 14, 2010 at 12:37:41 pm
Im authoring a BD disc and I got my subtitles today. I have 5 subtitle tracks. I always check my project after every operation I do to confirm that everything is workin as it should. Everything is fine until I add the last subtitle track (french). Then I suddenly get 5 error messages when I check the project. (one for each subtitle track)
"Subtitles too close for BD output"
Can anybody please help me out here? Any idea what this error is? I cant find anything to point me in any direction to solve this problem.
Im using ecore cs5 currently on a windows ultimate platform.
Pankaj Gauba
Re: wierd subtitle error cs5
on Jun 16, 2010 at 6:06:49 am
If a gap between two subtitle clips is less than 3-4 frames then this error appears.
The gap between two subtitle clip should be more than 3-4 frames in blu ray.
Roar Amundsen
on Jun 16, 2010 at 7:40:37 am
If somebody else has the problem:
I found out that if the video is over 1280x720 in resolution the subtitle gap cannot be under 5 frames. (Encores own restriction).
I was told that this is actually an old restriction in the early days of blu ray specifications. But encore still has that restriction.
