Encore Simple Question, Why is there a limit? why not ignore
COW Forums : Adobe Encore DVD
Travis Stuart
on May 19, 2010 at 2:26:48 pm
Why is there 1 gig limit for menus on DVD??
Cant i just ignore the warning when I have reached 1 gig limit and make DVD anyway? If i do what will happen.
I am making DVD catalog but its nothing but motion menu's so I plan to have more then 4 gig of menu's linked to each other.
Larry Applegate
Re: Encore Simple Question, Why is there a limit? why not ignore
on May 19, 2010 at 6:57:10 pm
The DVD Specs were written over 15 years ago, when microprocessors were very weak and had limited memory addressing capabilities. If you break this rule, your DVD will not play.
So your only choice is to use buttons over video in the VTS domain, which Encore does not support. So you will need to find a professional or prosumer-level authoring application. On Windows, there is Scenarist and perhaps others.
On Macintosh it can be done with DVD Studio Pro. here is an explanation from the DVD Studio Pro 4 User Manual:
http://documentation.apple.com/en/dvdstudiopro/usermanual/index.html#chapte...
Larry
Regards,
Larry Applegate
http://blustreak.dvdafteredit.com/
