Encore CS4 + Windows 7
COW Forums : Adobe Encore DVD
Clint Milner
on May 7, 2010 at 4:32:08 pm
Has anyone tested Encore CS4 with Windows 7?
I've read that people had problems with the beta of Windows 7, but I was wondering if there were any users that have used Encore on the a final build of Windows 7?
I have a choice of using Windows 7 Pro 32bit or Windows 7 Ultimate 64.
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
cowcowcowcowcow
minu sharma
Re: Encore CS4 + Windows 7
on May 10, 2010 at 5:37:11 am
Hi Clint ,
There are some issues on windows 7 with CS4.
Reason :
Encore installs an older version (not compatible with Windows 7) of the Roxio pxhelp driver
Workaround :
Install an updated version of the pxhelp driver from Roxio. The updated driver is available .
or
Disable or disconnect any internal or external Blu-ray or DVD burners.
Please have a look at:
http://kb2.adobe.com/cps/516/cpsid_51665.html
I am sure it will help.
Minu
Clint Milner
on May 14, 2010 at 9:13:17 am
Hi Minu,
Thank you for the reply, it was very helpful, and when I get around to rebuilding my laptop, I'll make sure to get that file.
Cheers,
Clint
12 GB DDR3 RAM
4 TB RAID 5
Rajesh Lamba
on May 14, 2010 at 7:37:21 am
Hi Clint,
I have been using Encore CS4 on Windows 7 and it works fine. However it is good to know about the Known issues with workaround from adobe knowledge base articles. here are some important ones.
http://kb2.adobe.com/cps/516/cpsid_51665.html 37k
http://kb2.adobe.com/cps/516/cpsid_51664.html 37k
http://kb2.adobe.com/cps/516/cpsid_51663.html 36k
As far OS is concerned, I would recommend Windows 7 Ultimate 64. So give it a try.
Thank you,
Rajesh
Clint Milner
on May 14, 2010 at 4:16:39 pm
Very helpful,
Thank you for the info Rajesh.
Clint
12 GB DDR3 RAM
4 TB RAID 5
