Encore on CD
COW Forums : Adobe Encore DVD
Brian Holson
Encore on CD
on May 5, 2010 at 8:36:05 pm
Is it possible to make a slideshow in Encore and put it on a CD instead of a DVD?
eric pautsch
Re: Encore on CD
on May 6, 2010 at 4:45:24 am
OK...I'll bite! Why would you want to do that? DVD players play DVDs :)
Brian Holson
Re: Encore on CD
on May 6, 2010 at 12:23:07 pm
Sorry, I should have explained better. Can an Encore slideshow be put on a CD?
Clint Milner
Re: Encore on CD
on May 6, 2010 at 1:57:14 pm
You can export your Encore project as Flash, and then if it's small enough, burn all the files to disc.
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
eric pautsch
Re: Encore on CD
on May 7, 2010 at 12:50:41 am
Well you might as well use Flash then. Besides there are tons of bugs in the Flash Converter. Encore is a DVD Authoring tool made for DVDs so No, you can put a DVD project on a CD. :)
Brian Holson
Re: Encore on CD
on May 7, 2010 at 12:33:26 pm
Thanks Guys, I assumed that was the answer but I thought maybe someone had a trick of how to do it.
I appreciate you taking the time to answer my question! :)
Mike Cohen
Re: Encore on CD
on May 7, 2010 at 5:58:43 pm
There are many, some free, slideshow makers - the end result of most is Flash, which can be embedded in a html document, and put on CD easily enough.
What is your application?
Mike Cohen
