Transcoding / Encoding for Blu Ray
COW Forums : Adobe Encore DVD
Jared Boice
on Apr 12, 2010 at 8:05:56 pm
Jared Boice here STILL walking on eggshells around Encore CS4. While I've had success with most of my Final Cut Movies in Encore, I've got a couple of Final Cut Movie files in my current Blu Ray project that will NOT transcode in Encore. It says, "Transcoding Now" but the progress bar NEVER moves. So I took it upon myself to encode my own MPEG-2s and then I realized that Adobe thought ahead even less regarding this one since Adobe Media Encoder can't seem to produce an MPEG-2 that does not require to be transcoded again in Encore.
m2v's maintain an "untranscoded" status and when I export a generic MPEG-2 from Media Encoder (with the .mpg extension) it still maintains the same "untranscoded" status as well as requiring import AGAIN and AGAIN for no reason? You heard that right, it will import and conform the audio and then as I move on to check the status of whether or not it requires to be transoded, all of a sudden it starts importing it again and conforming the audio. And then it does it again. WTF?
Someone please tell me what workflow works for them because I can't seem to find a single workflow that doesn't produce some kind of critical problem.
Mark Whittle
Re: Transcoding / Encoding for Blu Ray
on Apr 13, 2010 at 7:03:20 am
Me either. I just wasted two days having my system drive reformatted and everything re-installed in a vain attempt to get Encore working.
I haven't re-installed Toast in case that was conflicting, but that was my only way to get a Blu-ray done.
I managed a regular dvd yesterday but I just had a crash then while working on a Blu-ray (h.264). Encore CS2 on PC was great but CS4 is useless.
Does anyone have success with this on a Mac?
Mark W.
Warren Eig
on Apr 14, 2010 at 3:40:30 pm
I use CS4 on a Mac Pro all the time. No problems with basic Blu-Rays. I'm not doing advanced menus, but everything I was doing for standard Def DVDs in DVDSP seems to work when I create a Blu-Ray in Encore. I use Compressor to encode and author in Encore. Make a disc image and burn in Toast 10.
Warren
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.babyboompictures.com/BabyBoomPictures/AFX.html
http://www.babyboompictures.com/BabyBoomPictures/KnitWits_Movie.html
http://www.imdb.com/name/nm0251670/
EDITING REEL: http://www.babyboompictures.com/BabyBoomPictures/Editing_Reel.html
TITLE DESIGN: http://www.babyboompictures.com/BabyBoomPictures/Titles_Reel.html
Mark Whittle
on Apr 15, 2010 at 1:43:42 am
You've given me some hope then, Warren. Thanks.
I haven't re-installed Toast yet as I was worried there might be a conflict. When I'm feeling brave I'll install it.
I hope I have solved my crashing issues now after the OS re-install.
Cheers
Mark W.
