Length of stills in slideshow with long audio.
COW Forums : Adobe Encore DVD
Caston Sacmon
on Apr 7, 2010 at 11:57:07 am
Just a note for people who might encounter the same issue, because I had a huge problem and did not see a solution on here.
I had a 1+ hour long audio track and 6 stills that I wanted to cross fade and fit to the length of the audio.
When I went to build and burn I would get a "still length too long for slideshow" error. I only had 6 images in it and have not seen posts about this problem.
Over and over, I tried everything. Finally, I just duplicated the stills in the slideshow, put the same stills in so there would be more still and the would be shorter.
I put a cross fade on all and manual advance.
It worked. I guess there is an issue with the length of stills in a slide show. I did not know this.
Thought this might be helpful to have up here.
© 2018 All Rights Reserved
