button highlights when activated
COW Forums : Adobe Encore DVD
Brian Johnson
on Apr 6, 2010 at 3:23:07 am
I have an Encore project with a scene selection menu. There are 16 different text items to choose from, each with a button to the left that I created in Photoshop. It's just a white triangle with a transparent background. The background of the menu itself is black. The way I have my menu color set set up, the white triangle button moves around as you roll your mouse over the different selections. You only see one triangle at a time, depending on which item you roll over. If you click any of the triangles to activate the link, all 16 of them flash white at the same time just before it begins to play the video. Anyone know of a way to make it where you don't see all the buttons there at the end?
PS: Each button links to a chapter playlist, and each chapter playlist has just one chapter in it. It's dance numbers from a show that you can play individually as opposed to the "play all" option from the main menu.
