BluRay Menu Problem
COW Forums : Adobe Encore DVD
Vu Nguyen
BluRay Menu Problem
on Mar 26, 2010 at 4:27:11 am
Okay so I'm working on this project, a short project and want to author a BluRay DVD... so far things are good... and when I'm ready to build it... it kept failing on me with the error:
"Object: Main Menu, code 24, message: start exceeds stream duration"
I had this same error last night, and I was playing around on the menu property and all of the sudden it worked... So tonight, I made a change to the "motion" menu video clip so I reopen the project and try to build again... bam, I got the same error, so i though okay, I knew the trick so I did the same thing that I thought it worked last night and no matter how many times I tried it, it didn't work... what I did last night (if I remember correctly) was set the End Action of the Menu to go back to itself instead of Stop.
Now I can't do that anymore... maybe it wasn't really a solution but it worked last night, I was able to build the blueray image.
Anyone ever ran into this problem? my menu is a motion menu with the clip which is 20 seconds long that has music of the same length.
Please help!
© 2018 All Rights Reserved
