Change encoder to CCE, is possible?
COW Forums : Adobe Encore DVD
Luca Carlomi
on Mar 19, 2010 at 3:25:46 pm
Hi, I would like to encode my 20GB uncompressed DV AVI video with CCE SP2, but I can't select it in the Encore CS4 options, nor in Adobe Media Encoder.
I would prefer not to use the default CCE interface (the final file size isn't even accurate).
If I need another software, how can I automatically make the video size to fit perfectly on a DVD5 (having already encoded the audio in AC3 Dolby Digital)?
Thanks in advance!
Jon Geddes
Re: Change encoder to CCE, is possible?
on Mar 23, 2010 at 6:19:28 pm
Try HC Encoder. It's free, and the quality is just as good, and sometimes better than CCE.
You will need AVISynth to load your video though... not too big of a deal. Just install it, create a new .AVS file in the same directory as your video, edit it in notepad, and just add a quick script:
AviSource("uncompressed_master.avi")
Thats it. Then just load the .avs file into HC Encoder. There are a few more settings in the program, but it should be pretty straight forward.
Jon Geddes
http://www.precomposed.com
