subtitles: wont import txt.
COW Forums : Adobe Encore DVD
Chris Balogh
on Mar 18, 2010 at 7:30:09 pm
I have used the subtitle workshop for start and end times for creates a txt file literally designed just for ENCORE, i HAVE CS4 ENCORE. It will not import it throws up a window stating: THE SOFTWARE THATS USED TO DECODE THE MEDIA IS NOT AVAILABLE ON THIS SYSTEM. INSTALLING THE CORRECT DECODERS FOR THE FILES YOU ARE WORKIGN WITH MAY HELP...WHAT DO I DO NOW HELP?!
minu sharma
Re: subtitles: wont import txt.
on May 14, 2010 at 6:12:55 am
Hi Chris,
Encore accepts subtitles in UTF-8 format . You can save your subtitle file in subtitle workshop as " Save as Encore subtitles".
This file will be imported fine in Encore .
Please respond if that solved your issue.
© 2018 All Rights Reserved
