DVD Playback freezes
COW Forums : Adobe Encore DVD
Jeff Marier
on Feb 18, 2010 at 6:08:36 pm
okay, I have a 67 minute DVD with about 17 chapters. Around chapter 14 it starts freezing, read below to see what I'm running and what I've tried:
First I edited it in premiere elements 4.0 and tried to burn it from there.
Then I exported as a DV AVI file and tried to burn it from Encore at both 8x and 4x speeds (4x was the lowest allowable)
Then I tried to just create the Video TS file and burn it through Nero
Then I lowered the bitrate to 7.0
Then I changed it to CBR @ 7.0
With every change I made the problem was still the same.
Finally I burned it from elements again at 5.9mbps with just a few artifacts, but the quality has suffered a smidge.
Any ideas why I would have to lower the bitrate so much for a 67 minute dvd?
I am running a single processor (p4, 3.14), 1.5 RAM.
Adobe Encore Version 1.5
Taiyo Yuden Discs
Thanks in advance....(never had this problem before)
Nicole Haddock
Re: DVD Playback freezes
on Feb 24, 2010 at 8:53:01 pm
I never burn above 6.5mbps when it comes to SD DVDs. Playback CAN become an issue. How are you encoding the audio?
Jeff Marier
on Feb 25, 2010 at 3:22:35 am
My final DVD was burned from elements, so whatever the default setting is I don't know (you can't change that parameter, only the mbps)
With Encore I used the default setting originally, then changed it to PCM.
Would audio issues cause video to freeze?
