How to add the click' sound to a button and to set up Backgorund Music
COW Forums : Adobe Encore DVD
Art Alvarez
on Feb 15, 2010 at 10:17:07 pm
Hi:
This might be to easy but I do not find the way of doing it.
I have tried to set up on the Button>Properties>Transition' Tab (Assets) and attempting to use the pick whip to the wav file on my projetc' section but does not work. Is it possible to do this ?
By the other hand, I am attemting to set background music for my entire presentation but neither of the two methods I have tried generated the desire result:
. I added a Sound track to my timeline (with chapters on it), but it plays fine until I select the Chapter then the music stops and the chapter plays but w/o music. Once I get back to the Menu/Sub-Menu the music resumes.
. I can set it up on my Menu and Sub-Menus, but the music stops when I select and play the chapter.
Is there any way to set up backroung music regardless of the point of where you are at (Menu/Sub-Menus/Chapters)
Thanks in advance for your help,
