Encore Bluray settings
COW Forums : Adobe Encore DVD
Zvi Twersky
on Feb 10, 2010 at 7:36:27 am
I was told that you can fit 2 hours of full HD (1920x1080) on a 25GB bluray disk at its full res of 35Mbps. When I try to input these settings into Adobe Encore with a video of 1 hour and 58 minutes, it says that it will need 33.9 GB for those settings and won't burn it. When I tried (just out of curiosity) to set the transcode setting to automatic, it said there is now 10.5 GB of FREE SPACE. I'm afraid that the automatic setting is reducing the quality a lot so I didn't burn yet.
What are the best settings to get the most out of the HD quality and use as much of the 25GB as possible? And why am I not able to choose 35Mbps as target for 1:58 hours on a 25GB disk?
Jon Geddes
Re: Encore Bluray settings
on Feb 11, 2010 at 3:21:55 pm
Do not set the target bitrate above 20 Mbps. You can set the max up to 22 Mbps. I am assuming you are using h.264 codec if you want the best quality.
Those bitrate settings will yield excellent results. Anything higher, and you risk having serious playback problems on Blu-ray players as they are unable to sustain high bitrates read from burned media.
Pressed media (replicated) can be read as high as 45 Mbps.
Jon Geddes
http://www.precomposed.com
Zvi Twersky
on Feb 11, 2010 at 4:28:55 pm
Thanks. Can you give me good values for minimum as well? I use VBR so target will be 20, max 22... what should the minimum be? Thanks.
Jon Geddes
on Feb 14, 2010 at 4:20:38 pm
6000 kbps should work well
Jon Geddes
Zvi Twersky
on Feb 14, 2010 at 6:30:40 pm
6 - 8 is what I use for DV PAL (720x576) I'm talking here 1920x1080 Full HD.
Jon Geddes
on Feb 14, 2010 at 7:25:42 pm
I understand that, and I am talking MINIMUM. The target is the most important setting. For Standard definition I usually use a minimum of 1000 to 1500 kbps.
Jon Geddes
