Creating new menu as ntsc instead of pal.
COW Forums : Adobe Encore DVD
Christo Leone
on Jan 19, 2010 at 7:59:01 am
Hi there.
I'm using Encore CS4 and I set up a pal project but whenever I create a new menu, Encore makes it NTSC instead of PAL. I've found a roundabout way to fix this by creating a pal menu in Photoshop and then importing that into Encore but I'm wondering if there is a way to fix this in encore or to change the menu settings from NTSC to PAL since this is a very irritating step.
Thanx
Christo
Cheers vir eers
~ You are only limited by you're ignorance ~
Jeff Bellune
Re: Creating new menu as ntsc instead of pal.
on Jan 19, 2010 at 10:31:09 pm
If you used the New Menu command, then your problem is that your default menu is an NTSC menu. Either change the default or use the Library panel to add a PAL menu to your project.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Christo Leone
on Jan 20, 2010 at 9:25:20 am
Hia.
I made sure and my default settings are on PAL. Creating a new blank menu just makes it ntsc which it weird. Its ok though since I make all my menus in photoshop now anyway. Just abit anoying for when i wanna make a quick simple 1 button menu.
Thanks for the reply.
Cheers vir eers
Jeff Bellune
on Jan 20, 2010 at 1:56:44 pm
Make a blank PAL menu in Photoshop. Add it to Encore's library. Set the new blank PAL menu as the default menu. If you do all that, you won't have to use Photoshop every time, and you won't ever get a blank NTSC menu in a project again.
-Jeff
Christo Leone
on Jan 20, 2010 at 4:25:52 pm
hehe. that makes sense. Problem solved.
thanx
Cheers vir eers
