Timeline end actions not working: Encore CS4
COW Forums : Adobe Encore DVD
David Murray
on Jan 7, 2010 at 6:44:00 pm
I have a project set up with 3 videos with 3 buttons on a menu. I also have an intro video set as first play. The first play video/timeline end action works and opens the menu: no problem. When I select the first play button and play the video, at the end on the video, with the end action set to menu, the video will begin to play again and not navigate back to the menu. What's odd is that the end action works after the second time playing through. The same happens with the other buttons/video/timelines. Any suggestions? David
Jeff Wolstenholme
Re: Timeline end actions not working: Encore CS4
on Jan 12, 2010 at 6:46:01 pm
David, did you fix this problem? i am having the same issues, thanks.
Jeff Wolstenholme
on Jan 13, 2010 at 12:18:08 am
its been a while since i made a dvd, but i sat down and figured out the problem, on the menu your linking the timeline from you have to set link to the "timeline:chapter 1" and set the override back to the menu. that stops it from repeating.
Jeff Bellune
on Jan 13, 2010 at 12:28:09 am
Actually, the solution is (almost always) to *remove all overrides* from your project.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
