Chapter Markers not appearing
COW Forums : Adobe Encore DVD
Mark Whittle
on Jan 7, 2010 at 1:52:45 am
I have created a timeline in Premiere with Encore chapter markers, then sent to Encore CS4 via dynamic link. The chapter markers do not appear. This usually works fine. I have tried deleting the encore project and starting again but no joy.
I have read other posts with similar issues but their suggestions haven't worked. I am beginning to think CS4 has a lot of issues that need fixing. My old CS2 was very reliable but Encore CS4 (Mac version) crashes a lot on my new Mac Pro.
I just created a new sequence in the same Premiere project and placed a few chapter markers, then sent this to Encore. The markers appear! huh?
What is wrong with the original sequence?
Mark W.
Jeff Bellune
Re: Chapter Markers not appearing
on Jan 7, 2010 at 3:51:46 am
Did you give each chapter marker a name in the original sequence?
Are you sure you used Encore Chapter Markers and not ordinary Sequence Markers in the original sequence?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Mark Whittle
on Jan 11, 2010 at 2:08:59 pm
Yes I have names on all chapter markers, and yes, they are all Encore markers.
I have the same problem with another project with over 20 chapters. I just tried exporting a short segment as an MPEG2 file to see if the chapter data works that way, but no luck.
Mark W.
Jeff Bellune
on Jan 11, 2010 at 2:31:37 pm
Try your MPEG2-DVD export again with the following settings:
Preferences:
Export Settings:
-Jeff
Mark Whittle
on Jan 18, 2010 at 2:24:10 am
Thanks Jeff. Both of those settings were selected already.
Is there a prefs file or two I can delete to see if that helps?
Mark W.
Mark Whittle
on Jan 20, 2010 at 4:19:42 am
Thanks Jeff. I went to the path user/documents/Adobe etc but there is no folder for Encore in there.
Cheers.
Mark W.
Jeff Bellune
on Jan 20, 2010 at 12:30:49 pm
Unfortunately, I can't help you find where files are on a Mac. I'm on a PC.
-Jeff
Larry Zapotocky
on Jul 23, 2011 at 11:17:29 pm
Same Problem! If I only put a couple chapter markers it works. I have about 30 on the one sequence and it only shows one when I import into encore.
the only way I get it to work is to create a new sequence and copy and paste the entire timeline and then recreate the chapter marks. Works every time, but it is very frustrating.
Any fixex yet?
Larry Zapotocky
