Image file button highlight problem
COW Forums : Adobe Encore DVD
Bill Kimzey
on Dec 14, 2009 at 9:29:39 pm
I write a Blu-ray project to an iso image file from the build menu. Then, from the image file, burn a disc. The highlights are correct; all looks fine. Immediately thereafter, closing out the burn completed dialog, I burn a second disc. This time the highlights are displaced, and do not match up with the buttons. The pop-up menu is also scaled down from its normal size to something smaller, and displaced from the bottom to somewhere in the middle.
I've tried this 3 times. First disc successful; second disc, not successful.
Again, this is from an iso image file, so this seems like it should be impossible, with the point being that it's the same image.
I see several posts of others having highlighting issues, but really, I don't understand how this one can happen.
Running Snow Leopard and CS4.
Thanks for any insight.
© 2018 All Rights Reserved
