Why do long clips crash during transcoding?
COW Forums : Adobe Encore DVD
Les Fitzpatrick
on Nov 30, 2009 at 11:36:57 pm
In older versions as well as Encore CS4, longer clips, say in the neighborhood of an hour or more, crash the application during transcoding (typically at about the halfway point in the process). Is there an answer or work-around in order to successfully transcode a longer clip into Encore for authoring?
Jeff Bellune
Re: Why do long clips crash during transcoding?
on Dec 1, 2009 at 1:01:41 am
What kind of crash? Do you get an error message? Does En just disappear? Do you get a blue screen? Does your computer reboot?
What happens, exactly?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Les Fitzpatrick
on Dec 1, 2009 at 1:12:48 am
Jeff,
There’s no error message at all. The only fall-out includes an Adobe-generated crash report and the application is closed. At the moment, I’m running my sequence through Adobe Encode and will try to bypass Encore transcoding altogether. It seems odd I can author shorter sequences but nothing in the one hour or longer range. I never had this experience with DVD Studio Pro.
