Corrupted BUILD folder Encore CS4
COW Forums : Adobe Encore DVD
Matt Lee
on Nov 27, 2009 at 5:08:28 am
I typically use Encore CS4 to author the DVD and build the Video_TS folder, then burn to disc using Nero8. This is my standard method for making DVDs and suddenly on my latest project (DVD-5) I have IFOs and BUPs that don't match. What is the solution/work around for this?? I have burned this project before the same way and everything was just fine. Suddenly I open the project to make an updated VIDEO_TS folder and something is wrong with the build. My previous disc works fine, but everytime I try to build a new folder, the contents won't play or burn.
The ONLY thing that I can think of that has changed since my last build is I made a DLT with CSS encryption for this project. I opened the project again to make another check disc for the client (turing off CSS) and the build folder gets corrupted. My concern is that the DLT is corrupted, but I can't check that until it hits the replicator. If it IS corrupted, I need to know ASAP how to fix this! Thanks!
