Encore BluRay MPEG2
COW Forums : Adobe Encore DVD
silvan haselbach
Encore BluRay MPEG2
on Nov 23, 2009 at 10:15:26 pm
I encoded a MPEG2-HD file for BluRay with Soerensen squeeze.
mediainfo shows:
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : ├╝blich
Duration : 1h 40min
Bit rate mode : variabel
Bit rate : 22,9 Mbps
Nominal bit rate : 30,0 Mbps
Width : 1 920 Pixel
Height : 1 080 Pixel
Display aspect ratio : 16:9
Frame rate : 25,000 FPS
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : oberes Feld zuerst
Bits/(Pixel*Frame) : 0.442
Stream size : 16,0 GiB (96%)
adobe encore wants to transcode it again.
there is no option for not transcoding.
the transcoded file (of encore) have the same media-info data, only an other bitrate.
where can I configure encore, that it doesn't transcode the file again.
thanks for help and understanding my bad english ;)
Andrew Ford
Re: Encore BluRay MPEG2
on Jan 29, 2010 at 5:04:55 am
You also had this same problem using Compresser's Blu-ray settings. It seemed that Encore, at the time, didn't like anyone else's compression. Calls to Adobe seemed to hint at this, although that was a while ago.
Anyway, why are you doing Blu-ray in .mpeg2. You should be using h.264. Mpeg2 is only an option in Encore to support the very first, and now archaic, players. h.264 is where its at!
Always design with a purpose.
© 2018 All Rights Reserved
