stretched 4:3 playback
COW Forums : Adobe Encore DVD
Alan Condra
on Nov 22, 2009 at 7:07:05 pm
I am outputting a standard def 4:3 program with .9 pixel aspect ratio on standard DVD with Encore CS3 for playback on standard and hi def sets. I have check to make sure the picture aspects ratios within Premiere CS3 and Encore are set to 4:3 and the pixel aspect ratios are all set to DV .9. The program plays fine on standard def sets, but when I play in back on my Sony Blu-ray player on my Sony HD monitor, the 4:3 ratio image gets stretchd to the full 16:9 screen. There are a few option on the monitor that only stretch the image further making it worse. There are no image aspect ratio options on the Blu-ray player.
Is there something within Premiere or Encore that I am missing to prevent this from happening?
Thnx.
Alan Condra
Matt Lee
Re: stretched 4:3 playback
on Nov 27, 2009 at 5:15:36 am
Does it play properly on a standard DVD player? My aspect ratio test is to play the DVD on a computer NOT in full screen mode. If the window is 4:3 and the program is the correct aspect ratio, then everything is set up properly on the disc. If the program plays stretched in a 16:9 window on your computer, then the aspect flag is not correct on the DVD. I don't know much about Blu-ray players, but to test to make sure everything is correct, you should also try it on a standard DVD player on a 4:3 monitor as well as a computer not in full screen mode. Seems to me some newer TVs might not have the capabilities for playing 4:3 content properly.....can't confirm this for sure, but a client of mine is convinced of this as his 4:3 content plays back stretched on 50% of the TVs he has tried.
