Importing STL subtitles in Encore
COW Forums : Adobe Encore DVD
Marcello Mazzilli
on Nov 18, 2009 at 11:32:51 am
I need to convert STL files (the client gave me) to Adobe Encore format.
As far as I know Adobe Encore uses the following...
00;00;01;20 00;00;05;10 Hello this is a subtitle
1) What character Encore uses to have the title display on 2 different lines?
2) I tried some converters I found on the internet but none of them seems to work.. for a reason or another...
TITLE EXCHANGE PRO (Mac) is not yet working with Leopard
SUBTITLE WORKSHOP (Pc) has an Encore export option but doesn't seem to work. File created are not compatibile. In fact if I open them in Notepad I find ":" and not ";" between figures in time code and I find "|" to separate lines on the same subtitle.
Can somebody help me.
I just need a simple way to create Adobe Encore compatibile titles
siRoma di Marcello Mazzilli
Corporate video productions in Italy
http://www.siroma.com
Marcello Mazzilli
Re: Importing STL subtitles in Encore
on Nov 18, 2009 at 12:05:03 pm
I am doing some other tests and the issue seems to be the italian characters
à è é ò ù
All the subtitle format converters just copy the character and don't (should they?) convert them to an ANSI equivalent.
So.. How can I force Encore to adopt the italian character set?
Julie Setbon
on Dec 12, 2009 at 5:08:33 pm
You could try using a text editor (such as Ultraedit- they should have a free trial) to run a macro and change your script file and save it with a different encoding if necessary (UTF-8, UTF-16, ANSI).
Julie H. Setbon
iProbe Multilingual Solutions, Inc.
Tel. 212-489-6035
http://www.iprobesolutions.com
Language Versioning - Production & Event Support - Video Production
