Menu showing chosen picture
COW Forums : Adobe Encore DVD
Víctor Galdón
on Sep 28, 2009 at 7:58:09 am
Hi:
I don't know if it is possible but here I go:
I need a menu where you can see pictures as thumbnails/buttons and beside them the chosen one higher at the same time. I would choose another picture and becomes the higher picture of the menu so you can see the chosen picture and buttoms at the same time.
Now the big question: is this possible? :-S
Thanks.
Victor
Jon Geddes
Re: Menu showing chosen picture
on Sep 28, 2009 at 3:37:42 pm
Only possible if you create a separate menu for each button. The menus would all look the same of course, except for the chosen picture. You would then have to create pseudo buttons with auto-activate turned on for the navigation, so that when you navigate down from button one, it auto-activates the next menu which displays the image for button 2. It's a very complicated setup and causes problems with software dvd players (mouse-over does not cause auto-activate of next button). Also, any audio or motion you have for the menu will start over each time a button is highlighted. Usually people avoid this type of menu setup, but I have seen it on professional discs (Seinfeld TV Show DVD)
Jon Geddes
http://www.precomposed.com
