Playback issues on Sony DVP-NS77h player...
COW Forums : Adobe Encore DVD
Andrew Stone
on Sep 28, 2009 at 12:31:43 am
Hello all...
I am at a loss right now on this issue, looking for any advice...
I am burning dual layer dvds that play fine on my ps3, my computer, another sony dvd player. However on a Sony DVP-NS77h which my boss owns...
I am using Encore CS3 first I burnt on my LG burner with Verbatim printable, and Sony regulars. The Verbatim would lock up on playback. He uses these exact same dvds on his setup and they play fine. The sony disk would play fine on that dvd player.
I had a dying drive that I tried and it worked enough to get one dvd out, verbatim, which played on sony dvd player... So I went out and bought a new drive an HP and now the Sony disks, nor the Verbatim will play.
So it seems like a optical issue, I am just not sure what is causing it.
He uses Premiere 1.5 exports to avi, then imports that into an older version of encore and the burns on a toshiba I believe. He uses CBR of 8mbps
I encode in Premiere CS3 and use VBR with Minimum on 6, Max of 8, and the other setting at 7 (targetted rate?)
Any suggestions are welcomed...
© 2018 All Rights Reserved
