import export photoshop encore menu
COW Forums : Adobe Encore DVD
sietse bruggeling
on Sep 25, 2009 at 11:01:54 am
Dear all,
When I make a menu in Photoshop (using PSD pixels:720x576) and I import this in Encore (cs3) somehow the aspect ratio doesn't fit.
Does someone know how this can happen?
Same hapens when I export a video still from Premiere (cs3) and later on import it again; the size has changed.
I can't figure out how come and what is happening.
Sietse
Jeff Bellune
Re: import export photoshop encore menu
on Sep 25, 2009 at 12:05:17 pm
What is the Pixel Aspect Ratio (PAR) of the .psd file? Of the exported frame from Pr?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
sietse bruggeling
on Sep 25, 2009 at 1:02:00 pm
Your question is almost already the solution,
PAR is D1/pal (1.067)the exported frame from Premiere. It should be something else i guess.
Jeff Bellune
on Sep 25, 2009 at 1:18:23 pm
[sietse bruggeling] "It should be something else i guess."
No.
The 1.067 PAR is correct. I was concerned that you were trying to work with square pixels.
-Jeff
