looping point is the point where menu starts
COW Forums : Adobe Encore DVD
Magdalena Sadowska
on Aug 26, 2009 at 8:46:36 am
I've been using Encore for three days now, I've seen few tutorials how to use it properly and I burnt 2 menu DVDs so far without any problems... till now. I made very, very simple menu with one button. In preview everything seems to be perfect but every time I burn it into DVD, it plays only the looping point from menu instead of whole menu. I really don't understand what I'm doing wrong, on preview everything plays perfectly! Can anyone help me with this one please?
Many Thanks,
Magdalena
Jeff Bellune
Re: looping point is the point where menu starts
on Aug 26, 2009 at 12:00:15 pm
Is the menu set to "First Play"? If not, how do you link to it? Do you have any overrides set?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Jon Geddes
on Aug 26, 2009 at 3:09:58 pm
What type of asset are you using for the motion background?
Jon Geddes
http://www.precomposed.com
Magdalena Sadowska
on Aug 26, 2009 at 4:03:14 pm
Thank you for getting back to me!
The menu is very simple, created in After Effects. Despite button and actual video there is nothing else I added. All I did was just link it all up. First Play is linked up to Menu, and video loops after 7 seconds of the intro. That's about it (standard, very simple menu :)) Preview seems to work fine, I burnt it 6 times using different DVDs (first time I was using cheap ones and thought it could cause the problem) but still same thing is going on. Re-creating menu didn't help as well.
I took two sills from encore, maybe that would help to get an idea what I'm doing wrong :)
http://img5.imageshack.us/i/picture1vdy.png/
http://img514.imageshack.us/i/picture3jlq.png/
Thank you again!
Jeff Bellune
on Aug 26, 2009 at 5:32:34 pm
I don't see anything wrong in the screenshots that you posted.
Based on what I saw in the screenshots, the menu loops at 8 seconds, not 7 seconds.
Try extending the total length of the video from After Effects by a few seconds. Give the video a new name when you export. Link the menu Video and Audio to the new, longer video.
Build using an RW disc so you don't waste any blank discs.
-Jeff
